Overdrive Issue/Governor Replacement
Old Jun 29, 2010 | 02:28 PM
seuf's Avatar
seuf
Default Overdrive Issue/Governor Replacement
Got a 95 2WD. It keeps shifting out of overdrive? Any suggestions? Also, is there a write up on how to replace the transmission governor on a 42RH? Does the tranny need to be pulled?
Old Jun 29, 2010 | 02:52 PM
Crazy4x4RT's Avatar
Crazy4x4RT
Do you have any Codes? My guess a bad VSS Vechicle Speed Sensor. If needed check the FAQ in this section for a list of codes and how to read them without a code reader.
The Governor has nothing to do with the OD on your year.
Old Jun 29, 2010 | 03:15 PM
95_318SLT's Avatar
95_318SLT
+1 ^. OD on these trucks are electronically controlled, not hydraulic. You'd be looking at a sensor issue, like the vss, tps, or ect.
Old Jun 29, 2010 | 03:34 PM
seuf's Avatar
seuf
Thanks. I should have explained. The overdrive and governor are two seperate matters. I'm having an issue with the trans not shifting from 2nd to 3rd. This happens sporatically. I was told by a mechanic friend that it is probably the gorvernor. I guess there was a bulletin on this some time ago.
Old Jun 29, 2010 | 03:47 PM
95_318SLT's Avatar
95_318SLT
Ah ok. Thanks for clarifying. Yes, the lack of a 2-3 shift is definately a governor valve on its way out.
And now knowing what you just said, the two problems could be related. Fix the governor problem first and see if the overdrive problem clears itself up. If it doesn't, you should address it later.
Old Jun 29, 2010 | 04:47 PM
seuf's Avatar
seuf
Yeah sorry bout that. Any idea how to get to the governor? I've looked at the manuals. It looks as if it is internal.
Old Jun 29, 2010 | 05:39 PM
95_318SLT's Avatar
95_318SLT
It is internal... its located in the tailshaft I believe. I've never tried to take apart an automatic transmission, but I would assume the procedure is in the '95 Factory Service Manual we have available in this section's faq thread. If not, try the a500/a518 rebuild manual...
http://rapidshare.com/files/205488149/46rh.pdf
Old Jun 30, 2010 | 01:26 AM
shadowthedakota's Avatar
shadowthedakota
if your going to take it apart for the gov'nor then you might at well rebuild the thing for a fresh start. if you want i had a friend who got his A518 rebuilt for drag racing at Mayes performance for less than $700.
