6 of 8 plugs replaced and can't change the oil
Sup Forum,
So today we started a mini tuneup. Plugs, PCV Valve, Oil and filter. Typical stuff nothing fancy. I love when the normal stuff is a PITA...
So there are 2 plugs in the #4 and #8 that for some reason the wrench will not seat down over them. It protrudes from the metal heat shielding unlike the rest where it sat flush. I am not sure why this is. I cant see any blockage or anything around them but for some reason it just doesnt want to sit down in there!
Next thing i found when we were going to do the oil. The Prev. owner installed a quick oil change plug. It's like a Schroeder valve and when you press it in the oil comes out. Issue is i cant sit under there and wait for it all to drain w a screw driver! lol
So i think i am going to try and find a new oil plug to put in it cuz this one is lame.
Oh yea, guess what i found in the oil fill.... the Prev Owner had an issue with the oil fill cap apparently because it was wrapped in DUCT TAPE. Nasty duct tape that was all deteriorating and gross. I ran to the junk yard and bought a new one for a dollar.
Anyway thats all for now, will keep updating as things arise.
Laters!
Laters!
Get a pair of vice grips and pull the heat shields off then you'll be able to clean all the crap away from the plugs and get the socket to seat, they don't really seem to make any difference as mine have been gone since I bought my truck 2 years ago.
On the oil, it's probably a Fram Sure drain you can screw it out just like a regular plug.
