tranny trantsplant
Old Aug 20, 2010 | 06:46 PM
kavman's Avatar
kavman
Default tranny trantsplant
Will a tranny out of a 96 1500 work in my 94 Dakota with out a lot of changing wirs and such
Old Aug 20, 2010 | 08:04 PM
95_318SLT's Avatar
95_318SLT
No it will not. The '96+ (OBDII) transmissions have an electronically controlled governor valve and your computer has no way of controlling it.
Old Aug 20, 2010 | 10:50 PM
kavman's Avatar
kavman
can i swap computers or is that more than plug and play. i was also told that a 96 Dakota tranny would work 3.9 or 5.2 but i dont trust that source
Old Aug 20, 2010 | 11:05 PM
JGC403's Avatar
JGC403
Nope, completely different wiring harness. So the computer won't swap. The 3.9 and 5.2 have the same bell housing bolt pattern.
Old Aug 21, 2010 | 11:02 AM
kavman's Avatar
kavman
eaven if the plugins r the same
Old Aug 21, 2010 | 11:20 AM
Crazy4x4RT's Avatar
Crazy4x4RT
But don't expect the V6 trasmission to last under the V8 It didn't come stock under the V8's for a reason.
Just like said above it will not work. And the plugs are different. For your 94 the best options are 92-95 only.
Old Aug 21, 2010 | 11:29 AM
kavman's Avatar
kavman
92 - 95 Dakota only or will any of the full size trannys work
Old Aug 21, 2010 | 02:07 PM
Crazy4x4RT's Avatar
Crazy4x4RT
Yes Rams and Vans will work.
Old Aug 21, 2010 | 03:02 PM
kavman's Avatar
kavman
does the 96 1500 trans have 3 plugs or 2
Old Aug 21, 2010 | 05:31 PM
95_318SLT's Avatar
95_318SLT
It doesn't matter how many plugs it has! You aren't listening to us. The '96+ transmissions are electronically controlled, not hydraulically controlled like the '95 and older. Your computer has no way of talking to the electronic governor valve in the '96+ transmissions and therefore the transmission will never shift gears.
Also, your computer has 1 large 60 pin connector and the OBDII computers have 3 smaller connectors along with a lot more overall wires since OBDII monitors and controls more parts of the car/truck. You can't splice in an OBDII computer without changing the entire set of harnesses throughout the truck, so there is no good way to get a computer in your truck that will control a '96+ transmission.
Stop searching for a '96+ transmission and start looking for a '95 or older transmission or just rebuild yours.
