1995 Dakota- Hard Starting-Help
I have a new problem now, and need your advice.
My headlights do not work, when I first start my truck in the morning. All other interior/exterior lights, including parking lights and blinkers, do work, just not headlights.
I pull/push my headlight switch in/out repeatly, but they don't come on or even blink.
But......... 5 minutes or so down the road, they come on and work fine. Most other times during the day/afternoon they come on first try and work fine. When they work, they are consistant.
Headlight connection are tight, the big fuse looks fine.
I am beginning to believe that my truck is trying to convince me to move from (cold) Kentucky winters to Florida!!!
But seriously, any suggestions.
I may try a new headlight switch today. Its strange though, most bad switches can be "giggled" and the controlled item will flash on/off. This does not.
ONLY on morning (1st start) cold starts, the headlights won't work for about 5 minutes, then all is fine. Park lights (on the same switch) works fine.
Why would that be?
Why would that be?
