Hesitation
Old Oct 4, 2010 | 02:21 PM
InnerCityHillBilly's Avatar
InnerCityHillBilly
Default Hesitation
When i start the truck up in the morning and start driving there is a hesitation from when i press on the gas and when it starts to go, it dosnt just happen coming out of a full stop. it will happen when i am at higher speeds. after the engine has gotten to warm up it usually goes away, but today it was doing it after the engine was warm. i was wondering if the changing weather may have any roll in it
Old Oct 4, 2010 | 02:42 PM
issakar's Avatar
issakar
I dont know much about stuff n things. what about a Throttle Position Sensor? can someone else confirm/deny? It's not like a slipping/flaring is it? the RPMs dont shoot up?
Old Oct 4, 2010 | 04:00 PM
InnerCityHillBilly
they dont shoot up but the rpm will die down even with my foot on the gas. the rpm will only stay down for a second or 2
Old Oct 4, 2010 | 04:36 PM
issakar's Avatar
issakar
maybe test the TPS and see if it is acting up? this video is like old school but it talks about TPS issues and how to test.
http://www.youtube.com/watch?v=IsX5q3jBeBQ
Old Oct 4, 2010 | 08:14 PM
tmacdakota's Avatar
tmacdakota
How long ago since the last tune up? Could be the TPS or temp sensor or IAC, but when there's a distributor, plugs wires, etc. involved I always start checking the simple stuff first. The service manual in the FAQ section tells you how to test all of this stuff.
Old Oct 4, 2010 | 09:25 PM
InnerCityHillBilly
i have yet to do a complete one. i have replaced the sparkplugs, iac, and preaty sure the tps, but i will check the FAQ
Old Oct 5, 2010 | 08:03 AM
tmacdakota's Avatar
tmacdakota
Old wires and/or a worn/corroded dist. cap or rotor can cause hesitation like you describe. Changing the dist. cap is a real joy...engineered for access, not.
Old Oct 5, 2010 | 09:25 PM
InnerCityHillBilly
i forgot to say it feels like i am losing power an the rpms go down even when i dont let off the gas
Old Oct 6, 2010 | 01:21 PM
9652dakota's Avatar
9652dakota
this may or may not be helpfull. i had a simmilar issue with my when it was first warming up and i found a tsb to reprogram the controller (i work at a dogde dealer so it isn't like a superchips flash or anything) and it resolved all of my issues.
myne was a sag at part throttle after shifting to 2nd would usually pop through the intake. would clear up if i floored it and i'd fine the rest of that drive cycle. i noticed myne after fixing my kegger (belly pan leak on intake) and taking care of a few other vacuum leaks.
Old Oct 6, 2010 | 03:17 PM
InnerCityHillBilly
just talked to my mechanic and he said the first thing that came to his mind was a bad coil. i dont know anything about them so i am taking it into the shop tommaorw to see whats wrong with it.
