Will this programmer work?
Old Oct 4, 2010 | 05:21 PM
Bump's Avatar
Bump
Default Will this programmer work?
I know it says 2000 5.2, but theres not that much difference from 1995 to 2000 is there?
http://www.bismanonline.com/hypertec...mmer_iii_cheap
Old Oct 4, 2010 | 07:05 PM
Hahns5.2's Avatar
Hahns5.2
95 is OBD1, 00 is OBD2, HUGE difference!
About the only option you have is a Mopar PCM.
Old Oct 4, 2010 | 07:42 PM
Crazy4x4RT's Avatar
Crazy4x4RT
+1 to that.
Mopar Performance and http://www.bgperformancepcm.com/#magnum
Are the only true options.
Also a few other options. Here is a copy and paste from the FAQ2.
Computer Reprogrammers
There are very little for Dodge OBD1.
The best would be a Mopar performance computer. You can get them at http://www.mopar.com/performance/index.html or http://www.summitracing.com/
Jet chips has a plug in. It has been cheep quality and not worth it for most. http://www.jetchip.com/
You can get http://www.hypertech.com/Products/Po...uning%20Module (No reviews yet)
Here is one that flashes and can give you a handheld unit.
[size=4][size=4]At once this site had it listed but the site seems to be down now. http://nrar.com/
You can Also get get a multi-processor-driven signal manipulator that goes in-line between your engine and ECU.
http://www.unichip.us/dodge.asp
Petersen's 4Wheel & Off-Road Magazine did an article on it.
http://www.4wheeloffroad.com/techarticles/drivetrain/131_0707_1994_dodge_4x4_truck_dyno_tuning/index.html
Hey Hahns5.2 did you look into www.bgperformancepcm.com for your turbo setup?
Old Oct 4, 2010 | 08:39 PM
Hahns5.2's Avatar
Hahns5.2
Not really, I doubt they could make the PCM compatible with boost, Megasquirt's cheaper anyways and I don't have to send it off to have it tuned..
