Front Suspension Bushings...what do I need?
I'm getting ready to replace all the front suspension bushings on my '94 dakota.
Not being familiar with the parts (or terminology) required, where could I get a list of the parts I need. Pretty much all the rubber is gone or dry rotted.
Any information I could get would be greatly appreciated.
Napa lists them available. But they may be the 2wd
EDIT:
Yup 2WD......
THANKS Crazy4x4RT !!!
I had pressed the old ones out and sand blasted the arms. Hadn't put the "new" ones back in...
Saw your post and went and checked... they sent me 2wd bushings. :P
Good thing i kept the old ones... (they just press out unlike the upper ones which I had to burn the rubber to remove)
Looks like I may have to find some spares in a wrecking yard, for future use.
From the diagram at www.makeitdodgeparts.com, it makes it look like they didn't sell the bushing separately... only with the control arm... any idea if they were ever available separately ?
1. Junkyard and pick up a control arm with decent bushings.
2. Try to find an online manual with dimensions of some busings. Then measure what you need and try to find one that will fit.
Napa sometimes will help in that kind of a search.
