46RH question
I went to get a 46 for my 318 swap today and my friend looked it up at the yard and said 94-95 dakota only? Is that right? I would have thought any 46 out of ram or van would work. Is the cables or wiring different? I need help, this is getting agrivating
The 46rh was offered in 94 and 95 rams behind the 5.9l magnum. Usually in 2500 and 3500 chassis. It is noted that it was offered in some dakota's between 92 and 95 as well. The 46rh has a hydraulic control versus the electronic control of later years and the governor's are different. The later years are 46 re. The a518 is the same trans (Chrysler redid the nomenclature). The trans you are looking for has the 3 pin connector versus the 8 pin of the later models.
Trending Topics
I have relevant data to contribute more info. I believe the A518 was offered from 90 to 95 in dak's, ram's and van's of the 5.2 and 5.9l type. When Chrysler updated there nomenclature to the newer system the numbers changed a bit. However, I believe that the 94-95 had the lockup feature standard as opposed to an option in earlier models. This data is unfortunately based on internet searches from secondary sources.
