driving lights.
Old Oct 12, 2010 | 01:31 PM
9652dakota's Avatar
9652dakota
Default driving lights.
on a 96 totally stock truck what driving lights have you all found to be an effective upgrade that didn't just look out of place? i want to keep the air dam and bumper the same if possible and im having a hard time picturing what would goo good with the rest of the truck and not require big time mods. i don't want to look like a mudder or anything like that. just need em to look like they belong. any ideas?
Old Oct 12, 2010 | 01:38 PM
HammerZ71's Avatar
HammerZ71
What about a nice set of Hella 500s behind the grill??? Hidden but very functional...
Old Oct 12, 2010 | 06:21 PM
melodytoinvent's Avatar
melodytoinvent
Yeah, Like Hammer and his bad *** truck said lol. Or something like I got. I think it gives the truck a kinda bulldog look.
Old Oct 12, 2010 | 07:03 PM
reeferbro0622's Avatar
reeferbro0622
I've noticed my regular driving lights pretty much stink I have to put headlights on backroads without lamps to even see in front of myself. Other cars don't even flash me when they drive by... Im debating what to get as well.
For safety reasons ofcourse... all safety.
Old Oct 12, 2010 | 11:16 PM
9652dakota's Avatar
9652dakota
how bright are those melodytoinvent. part of my hold up is worry about melting plastic because i want something brighter than my head lights or at least with a long wide beam. i fixed it on a ranger so that a relay powerd the high and lows at the same time but i like my dak enough that i'd rather do it right if i can. and driving lights just make sense to me. my low beams suck and my high beams should be lowbeams. (also the case with the ranger) but that fix didn't give me any more light out at a distance just more right there infront of me. i've had the lil round amber fog lights before and they are ok for there intended purpose but not quite what im after. as for the hella idea have you had any probs with heat on the grill?
Old Oct 13, 2010 | 02:48 PM
melodytoinvent
They're aight. I get flashed when I have them and my dims on so people seem to think they're bright lol. And they work good on trails, but I shoulda bought the brighter lookin, white/bluish lookin ones cause what I got is bright, but they kinda output the yellowish tint ya know? But definitely still worth the money. Oh and they light up the road good so yeah, not bad for 20 dollars.
Old Oct 13, 2010 | 06:16 PM
shadowthedakota's Avatar
shadowthedakota
i bought a small set of cheapies and they worked well. then i upgraded to 100w bulbs and they got wrecked while offroading. but you can get small ones and mount them on the airdam like i did.
Old Oct 13, 2010 | 07:27 PM
festerw's Avatar
festerw
I don't think you could fit them behind the grille, there isn't a whole lot of room back there.
Whatever you get make sure they have a trapezoid shape beam they'll give you the best light coverage and nothing over 55w if you want them to be half *** legal.
That said I've got Hella 500's that I really like.
Old Oct 16, 2010 | 04:25 PM
9652dakota's Avatar
9652dakota
i appreciate all of your input guys i'll have to do some shopping around and see what i can find in the way of smaller ones. i have decided when i do this ill make a new high amp harness for the lights and just run it all off of relays and big wires so that i can simplify the install and not have more switches in the cab. i had thought of maybe fog lights with my lobeams that would switch off for highbeams and have driving lights for them. deffinetly have some thinking to do. again guys i appeciate it.
Old Oct 18, 2010 | 12:55 PM
9652dakota's Avatar
9652dakota
well i settled on a set of cheepies from wally world. platinum burners (ill get the model number when i get home.) wired em in with a relay and cut the high beam wire in to. the relay powers the high beams and the driving lights. i even put a switch under the hood so i can shut em off if needed. holy god those things are brighter then 8377. next up maybe do the same for the lowbeams with a set fog lights?
