4x4 inop after head gasket replacement! 4x4 engaged lights also inop!
Old Nov 3, 2010 | 04:15 PM
nealwiley's Avatar
nealwiley
Default 4x4 inop after head gasket replacement! 4x4 engaged lights also inop!
Worked fine before head gasket, any ideas? Does vacuum have anything to do with 4x4? 1985 model
Old Nov 3, 2010 | 04:25 PM
Den37's Avatar
Den37
If your truck is like my 91,vacuum has EVERYTHING to do with 4X4.You should have a vacuum line down to the switch on the transfer case.Look to see if you got all the vacuum lines in the right place.
Old Nov 3, 2010 | 05:26 PM
Crazy4x4RT's Avatar
Crazy4x4RT
I'm assuming you have a Ram and not a Dakota. Due to no 85 Dakota and your vehicle bar says a 85 D 150. You are in the Dakota section. 80's did have vacuum operated CAD and Auto-hubs. So it is possible you didn't put back on a line or put it in the wrong spot.
Old Nov 3, 2010 | 07:38 PM
Den37's Avatar
Den37
Originally Posted by Crazy4x4RT
I'm assuming you have a Ram and not a Dakota. Due to no 85 Dakota and your vehicle bar says a 85 D 150......
I gotta learn to read more.
