just need a little help
Old Nov 4, 2010 | 04:09 PM
dakota26's Avatar
dakota26
Exclamation just need a little help
hello i have a 96 dakota 3.9 4x4 slt i need to know what Transmission will work with my truck or wher i can get a complte rebuld kit for the 42 re thx bobby
Old Nov 4, 2010 | 04:26 PM
Crazy4x4RT's Avatar
Crazy4x4RT
Like you said you have a 42RE. The 96-up will work. I'm not 100% that all 42RE's will work due to some may have different spline count ect. The closer to your year the better.
As far as a rebuild kit I would say Napa. www.Napaonline.com
Old Nov 4, 2010 | 08:04 PM
dakota26's Avatar
dakota26
thank you crazy4x4rt and what do you mean by the different spline count
Old Nov 5, 2010 | 08:49 PM
dakota26's Avatar
dakota26
The 42RE 4 speed automatic transmission was used in 1993.5 to present Jeep Grand Cherokees with 4.0L engines is this ture and if so can i use it on my truck ?
Old Nov 8, 2010 | 03:24 PM
dakota26's Avatar
dakota26
Unhappy
hello im having problems geting a 96 tranmission so can you plz tell me what yrs will work in my truck with out changing anything thx bobby
Old Nov 8, 2010 | 03:45 PM
Crazy4x4RT's Avatar
Crazy4x4RT
Spines are the grooves on the on shaft where the slip yoke connects. If needed get the new transmission slip yoke.
I doubt it did at least not till 96. Even if it did it wont work. You will need one off the same engine as yours. Ram, Vans, Dakota will work. 96-up. Check this list. Also all the info you need is in the FAQ in this section.
http://www.drivetrain.com/parts_cata...do_i_have.html
Also you can call up a transmission shop and ask.
Old Nov 8, 2010 | 09:42 PM
dakota26's Avatar
dakota26
ty 4 the help
