about to do 3.9-5.9 swap, some questions
Old Nov 7, 2010 | 12:20 AM
Hahns5.2's Avatar
Hahns5.2
They work just fine with a manual transmission.
5.2 and 5.9 flywheels and flexplates are different, the 5.9 is externally ballanced. I would use the 3.9 pressure plate and disk.
Old Nov 7, 2010 | 12:36 AM
93formula's Avatar
93formula
Thanks for the input I'm assuming you mean the mopar auto PCMs.
And thanks for clearing the pressure plate / clutch issue.
Old Nov 21, 2010 | 07:07 AM
digdaddy1221's Avatar
digdaddy1221
Smile Covering my bases
I know this has been covered well in numerous threads but I still have a couple of questions, as I am about to drop a 5.9 in my 99 Ram 1500 5 speed. I am also planning on keeping the 5 speed manual set up, and plan to splice the 7 & 8 injectors into my existing harness. The donor vehicle is a 99 Durango automatic that was totaled. It was loaded with options, where as my p/u has a base set up. Does this effect the PCM as far as the auto to manual trans, and then the difference in accessories ? My plan was to use the PCM from the V-8 donor vehicle, but am not sure ? I know I will need a flywheel for the 5.9, and plan on getting the truck style oil pan , and also doing the plenum plate upgrade. I think I should go ahead and do the water pump and those impossible to get to hoses as well. Other than that the engine runs well. Any input as to things I should also cover while the engine is out ? Also I understand there is some question as to the tranny holding up ? I am not sure which one I have, but as I've said, my p/u is the base model and my guess is that I have the base tranny as well. The only pulling I do is to and from the boat ramp , and at 47 have outgrown my need for speed. Do I need to worry about the trans, or will I be fine under moderate conditions ? Thanks in advance as Dodge Forum has always been a wealth of info.
Old Nov 21, 2010 | 09:05 AM
DarkKnite2009's Avatar
DarkKnite2009
i would swap for a stronger trans because your still towing with it. you'll be putting all that V8 through the V6 tranny when towing and it will eventually give.
Old Nov 21, 2010 | 02:17 PM
Hahns5.2's Avatar
Hahns5.2
The NV3500 is fairly tough, mines holding up very well to my abuse.
How much do you plan on towing?
Old Nov 21, 2010 | 08:07 PM
93formula's Avatar
93formula
Anyone know if a jeep Cherokee v8 tb and or throttle cable from a 94/95 will work?
Old Nov 22, 2010 | 05:48 AM
digdaddy1221
I have a 21' Chris Craft, with the trailer and a full load of fuel probably talking less than 3500lbs.
Old Nov 25, 2010 | 12:03 AM
413maxwedge's Avatar
413maxwedge
A jeep cherokee never came with a v-8, now a grand cherokee came with a v-8 and I'm sure the tc is differant.One word can get you into deep trouble be careful.lol
Old Nov 25, 2010 | 03:27 PM
93formula's Avatar
93formula
lol, yeah i meant the grand cherokee's.
Old Nov 25, 2010 | 11:53 PM
93formula's Avatar
93formula
Found the manual 5.9 mopar performance pcm.
http://www.summitracing.com/parts/DCC-5249543/
Anyone tried the ram throttle cable?
Also if I find a ram 5 spd is the transfer case the same? Found a nv3500 from a 96 ram
