about to do 3.9-5.9 swap, some questions
Old Nov 26, 2010 | 02:33 AM
  #21
Crazy4x4RT's Avatar
Crazy4x4RT
If the Ram with the cable is the same around the same year as yours it will work. I have a 94 Rams cable. Yes the transfer case is the same. If I remember right 95-up Rams and Dakotas came with a higher spline count on the rear slip yoke. So you should be okay.
Old Nov 26, 2010 | 09:42 AM
  #22
93formula's Avatar
93formula
Thanks for the info. I'm gonna try and snag the ram transmission. Guy claims 80k Kms and is asking 350.00 for it
Old Nov 26, 2010 | 06:59 PM
  #23
93formula's Avatar
93formula
just found out the nv3500 is from a diesel truck, will this work for me?
Old Nov 26, 2010 | 09:12 PM
  #24
shadowthedakota's Avatar
shadowthedakota
correct me if i'm wrong but i believe the nv4500 came behind a diesel which requires a 2in body lift(or reshaping of the transtunnel)...
when you get another transmission i would suggest spring for a v8 clutch too. i have a v6 clutch on mine and it lasted a month then everything went to hell and back with it.
and the nv3500 came in a 95+ dodge ram v6 and v8(i got mine from a 96 v6 ram)and 94+ dakota v8
Old Nov 26, 2010 | 10:38 PM
  #25
93formula's Avatar
93formula
Yeah there was a miscommunication between myself and the seller. Turns out his truck is a diesel and he is parting out a gas ram. So looks like i'll grab it. Now anyone selling a transfercase lol.
