cut-out and motor tach at 3000rpms
Old Nov 9, 2010 | 01:58 PM
9652dakota's Avatar
9652dakota
the round end of the sensor that goes inside the bell is where you glue it to. i always just used rtv or the little green button. the new sensor probbly had it on it (usually do.) the part you are referring to is the flexplate. it has the windows cut in it for the sensor to read off of. if it's not round (almost perfect) that could cause it to not read.
Old Nov 9, 2010 | 06:51 PM
93DakotaMagnumV8's Avatar
93DakotaMagnumV8
Thanks, im gona get a new flexplate because i know without a doubt that the holes arent perfect. Much Appreciated.
Old Nov 9, 2010 | 06:53 PM
93DakotaMagnumV8
what would the reason be for the (rev limiter?) weird, ill see if i can get a vid on here and yall take a look.
Old Nov 9, 2010 | 07:09 PM
93DakotaMagnumV8
http://www.youtube.com/watch?v=U51pHXpVlhc
Old Nov 10, 2010 | 08:46 PM
9652dakota's Avatar
9652dakota
thats not a rev limiter. its losing the crank pos sensor. the tak jumping like that does not happen it just lightly bounces nothing light that. and it's no problem man. just keep us posted and i hope that's all there is to it
Old Nov 10, 2010 | 10:13 PM
93DakotaMagnumV8
well ive spent 280 on dodge sensors ans 52 on aftermarket sensor, and the 55 dollar flexplate should fix the problem, i dont want to take transmission out again though.
Old Nov 11, 2010 | 01:04 PM
9652dakota's Avatar
9652dakota
i don't blame you on that. the truck is built around the drivetrain lol.
Old Nov 11, 2010 | 06:58 PM
93DakotaMagnumV8
i just bought the flexplate, now just looking for a day to do it, ill let u know what happens with it.
Old Nov 13, 2010 | 09:18 PM
93DakotaMagnumV8
im stuck, got 3/4 bolts off driveshaft from transfrer case and rounded off the 4th, idk what to do lol
Old Nov 14, 2010 | 11:09 AM
9652dakota's Avatar
9652dakota
if there is room for it hammer an easy off on there or maybe try curved jaw pliers. i used a hammer and chissel (on the side of the bolt to turn it the way i wanted) to break bolts loose. worst case scenario you could weld a 1 doller socket to it. done that in a pinch to. maybe a dumb question but you using 6 or 12 point sockets?
