Tranny slips when warmed up
Old 11-12-2010, 11:31 PM
94dodgenoob's Avatar
94dodgenoob
94dodgenoob is offline
Default Tranny slips when warmed up
I just bought this 94 Dakota 4x4 with a v6. The tranny slips once it gets warmed up. Fluid looks and smells clean. Any ideas I'm new to owning a dodge truck. It has 136000 miles. Thanks
Old 11-13-2010, 01:34 AM
Crazy4x4RT's Avatar
Crazy4x4RT
Crazy4x4RT is offline
Old 11-13-2010, 07:22 AM
94dodgenoob
I didnt even think to check it. I'll let it warm up today and have a look.
Old 11-13-2010, 07:36 PM
94dodgenoob
I let the truck warm up and checked the fluid and it was about a 1/2" on the stick just covering the M in Min.
Old 11-14-2010, 12:27 AM
issakar's Avatar
issakar
issakar is offline
If it's reading "Min" it's actually too low.
As Per the FSM:
Originally Posted by Factory Service Manual
(7) Remove dipstick and check fluid level as fol-
lows:
(a) Dipstick has three indicator levels (Fig. 8)
which are a MIN dot, an OK crosshatch area, and
a MAX fill arrow.
(b) Correct maximum level is to MAX arrow
mark. Correct acceptable level is to OK mark in
crosshatch area. Incorrect level is at or below MIN
dot.
(c) If fluid is low, add only enough Mopar ATF
Plus to restore correct level. Do not overfill.
(d) If transmission is overfilled, fluid can be
removed with 1/8 to 3/16 in. diameter tubing and
suction gun. Tubing will have to be adapted to noz-
zle of gun and be long enough to extend down fill
tube and into transmission oil pan
Fluid level is suppose to be checked while vehicle is in neutral as well.
Good Luck!
Old 11-14-2010, 01:58 AM
Crazy4x4RT's Avatar
Crazy4x4RT
Yes and engine running at warm temp. And level ground. Check it 4-5 times, clean it off in between.
Old 11-14-2010, 11:38 AM
94dodgenoob
Had it on level ground and check 3 or 4 times,but I'm thinking since its low I should drop the pan change the filter and add new fluid. Also figure out how to adjust the bands. I just bought this truck so I have no history on it.
Old 11-14-2010, 12:29 PM
Crazy4x4RT's Avatar
Crazy4x4RT
Yes that is best. The service manual is in the FAQ in this section. It has all the details on the band adjustments.
Old 11-15-2010, 12:30 PM
kahanabob's Avatar
kahanabob
kahanabob is offline
i adjusted the bands on my 90 easy ,i over tightened 1/4 turn since 160k miles..
Old 11-16-2010, 12:08 AM
94dodgenoob
So do I need a inch lb torque wrench to adjust the bands? What do mean you over tightened them?
Quick Reply: Tranny slips when warmed up
