Anyone taken the fuel injection out?
Old Nov 15, 2010 | 10:48 PM
bowhunter2k9's Avatar
bowhunter2k9
Default Anyone taken the fuel injection out?
I want to get a different intake and put a carburetor on my truck, but idk anything about the computer hooked to the injectors.... Has anyone done this conversion?
Old Nov 15, 2010 | 11:07 PM
Crazy4x4RT's Avatar
Crazy4x4RT
I don't remember what engine you got but I would say it isn't worth it. Why do you wan to convert anyways? The EFI will get best MPG and best HP and TQ numbers.
Old Nov 16, 2010 | 12:27 PM
Hahns5.2's Avatar
Hahns5.2
Why? You have nothing to gain by doing so.
Old Nov 16, 2010 | 03:00 PM
misfitdakota_95's Avatar
misfitdakota_95
plus, if you do the fuel injection to carb conversion, you'll need to have a fuel pressure regulator in line from the tank to the engine. It'll have to be lowered down to around 4-5 PSI because stock magnum engines make 39 PSI from the fuel pump, which will flood a carb the second you turn the key on. Also, magnum engines don't have a slot in the engine to hook up a mechanical fuel pump to the engine.
Old Nov 16, 2010 | 03:04 PM
siggie30's Avatar
siggie30
They are correct. I am actively doing this conversion (3.9l TBI to 5.9l Carb), but it is something that "I am doing" and wouldn't recommend it just for the sake of not having a computer. The ECU is better unless you have a goal, and then it (the ECU) is better for power adders later. I am deleting the ECU because I am a little older than most and am more comfortable with them. I do not, however mind changing the sensors and such, but I am a nitrous guy, and I wanted a little old school for my truck.
