ball joint socket absolutely necessary?
Old Nov 16, 2010 | 08:15 PM
4x4Dakota93's Avatar
4x4Dakota93
Default ball joint socket absolutely necessary?
for upper ball joint...
is it???? cause i really wanna change this weekend and i cant find a place that ship under a week....
could a big adjustable wrench work???
anyone done it???
Old Nov 16, 2010 | 09:58 PM
Crazy4x4RT's Avatar
Crazy4x4RT
The socket is best. But a few others have use an adjustable wrench or a pipe wrench. When you buy the new Joint you can see if you have a large enough one. Make sure and spray some extra WD on it. And use a large bar to the wrench to use as a cheater if needed.
Old Nov 17, 2010 | 08:03 AM
89newbie's Avatar
89newbie
Both dad and gdad were wrenches. Next door neighbor was the same all believed in heating any suspension part prior to working on it to break the rust bond. That tip many years ago plus the WD-40 makes the job go much smoother. Crazy has an excellent point also, my longest cheater pipe is about 8 ft. long,
Old Nov 17, 2010 | 08:22 AM
dbilik's Avatar
dbilik
I used a big pipe wrench to get mine off, and then a BFH for the lowers. I put it back on with a spud wrench so I didn't damage the new ball joint for the upper.
