89 dak 4x4 with 3.9 want to do a 3.9 mag swap
Old Nov 17, 2010 | 08:32 PM
hydrodmg's Avatar
hydrodmg
Default 89 dak 4x4 with 3.9 want to do a 3.9 mag swap
ok guys as the title states i have a 89 3.9 and i found a 3.9 mag with computer and harness for $175 can it be done and who has done it and what tips can be given
Old Nov 18, 2010 | 02:20 AM
Crazy4x4RT's Avatar
Crazy4x4RT
Yes it can be done. I believe it will bolt into your motor mounts. It will take time, but at the end it will be worth it. We have the service manual and wiring diagrams in the FAQ, to help with your swap. Post up pics when you get it done.
Old Nov 18, 2010 | 06:01 AM
hydrodmg's Avatar
hydrodmg
Hey thanks a lot for the info
Old Nov 18, 2010 | 06:16 AM
hydrodmg's Avatar
hydrodmg
And I was looking to gather information from somebody who has done thi exact swap before to give me any and all information they can share this will be my first swap I have ever done and with this truck being my daily driver I am looking to have all my homework done ahead of time to make this project go as fast and as smooth as possiblem. The mag has 110000 miles on it any major things I should do to the motor before I put it in the truck?
Old Nov 18, 2010 | 01:38 PM
siggie30's Avatar
siggie30
If I hadn't allready had a v8, I would of done this swap. Yes, the mag will bolt in. Hopefully, you have the donor vehicle, or access to it (or a similar model). The wiring loom is straight forward. Not sure about your bulkhead connector, but I am confident there are not alot of changes. Are you taking the transmission too? If you do, then you do not have to worry about alignment issues.
On a side note.... what exactly are you referring to when you ask about "What to do"? Performance, maintenance or appearance?
Old Nov 18, 2010 | 06:15 PM
hydrodmg's Avatar
hydrodmg
no donor but i will have the wiring harness and cpu
Old Nov 20, 2010 | 01:37 PM
hydrodmg's Avatar
hydrodmg
5ok guys i got the motor today and i need to get a few more parts for it but i will satrt a build thread and will include pics of what i am doing
Old Nov 21, 2010 | 09:21 PM
schottyrotten's Avatar
schottyrotten
im looking forward to doing this swap also. keep us up to date please.
