new here havin issue with sending unit
Old Nov 20, 2010 | 07:46 PM
dszx13's Avatar
dszx13
Default new here havin issue with sending unit
bought the truck in july an sending unit didnt work. i got one from the dealership i worked at. put it in an worked great. month later pump itself went out. got a aftermarket pump put in an sending unit didnt work so i swapped it out an samething tried once more an the same thing. bought a haynes manual last night an cant find the wiring diagram for the sending unit anywhere. i kno its hooked up right ive had fuel issues with 4 other vehicles in the past but this one stummped me. any suggestions??
Old Nov 20, 2010 | 08:15 PM
oxygen454's Avatar
oxygen454
I believe there is a factory manual for our truck in the faq. I had mine go on me, replaced it and had no problems since. It is possible to have a short in the wiring that is killing your pump. Is your tank and fuel filter clean?
Old Nov 20, 2010 | 11:35 PM
dszx13's Avatar
dszx13
yeah they are
Old Nov 20, 2010 | 11:49 PM
oxygen454's Avatar
oxygen454
So your having your fuel pump and sending unit dying? That is really weird. It sounds to me like a wiring issue. Bad ground or connection somewhere? What fuel do you run in your truck?
Old Nov 21, 2010 | 02:55 PM
dszx13's Avatar
dszx13
the pump works perfect the sending unit wont work an i swapped the aftermarket pump out 3 times with a different one
Old Nov 21, 2010 | 03:08 PM
siggie30's Avatar
siggie30
Personally, I think you have a break in the line somewhere. Did you do a continuity check?
Old Nov 21, 2010 | 03:14 PM
dszx13's Avatar
dszx13
i got feed up with it an stopped messin with it but i really wanna know how much gas i have lol. the gas light is always on an reads 1/8th no matter how much gas i put in
Old Nov 21, 2010 | 04:29 PM
oxygen454's Avatar
oxygen454
Has it always shown 1/8th? and do you know for sure if your floater fell off or not in the tank? If not I would agree, you have a electrical issue.
Old Nov 21, 2010 | 05:34 PM
siggie30's Avatar
siggie30
Old Nov 22, 2010 | 06:55 AM
dszx13's Avatar
dszx13
when i got the sending unit from the dodge dealership worked great month later that pump went out so i got a aftermarket one i pulled each pump out to return an everything was there (ive exchanged the aftermarket pump 3 times)
