waterpump issue?
Old Dec 11, 2010 | 09:13 PM
  #21
shadowthedakota's Avatar
shadowthedakota
i've been checking the coolant level the last few days and the coolant level is the same as when i filled it up and it hasn't leaked since. my grandpa thinks that maybe it just had an air bubble in it. the gauge hasn't gone up past 1/4 on the scale.
i found some pics i took. i apologize in advance for the quality(i changed a setting a while back and now i can't get it back to normal)
the acc. and belt
the hood. i cleaned that sticker a few weeks ago.
the lower rad hose(where it connects to the water pump)
Last edited by shadowthedakota; Dec 11, 2010 at 09:14 PM. Reason: forgot last img tag
Old Dec 12, 2010 | 02:45 AM
  #22
DAKOTAJIM's Avatar
DAKOTAJIM
Default Removing a/c
Just a word of warning. You said you were planning on getting rid of the a/c and i wanted to warn you that refridgerant can cause blindness so it would be a good idea to have a shop evacuate the system before you try to disconnect the a/c lines. You might have to change the serpentine belt, if you have one, unless you leave the compressor in place as the old belt won't fit without the compressor.
Old Dec 12, 2010 | 02:48 AM
  #23
DAKOTAJIM's Avatar
DAKOTAJIM
Sorry i just noticed the serpentine belt in your pictures.
Old Dec 12, 2010 | 07:24 PM
  #24
shadowthedakota
I know about the refrigerant. i dodged that bullet a few weeks ago with my dads b2500 when i changed teh compressor for him, good thing it was empty. i plan on it but right now i'm doing excellent with saving money and such i'm waiting on it which is why i won't be fixing anything on it for a while. i've been lucky enough that my company is doing work on my house so i haven't had to drive anywhere or i'd have been in a ditch a lot the past few days with my almost bald(less than a yr old) front tires and nothing to weigh my truck down. i pan on having the ac system emptied by a mechanic shop(unless my dad does it for me since he has the proper tools) before i mess around with it.
Old Dec 30, 2010 | 05:02 PM
  #25
shadowthedakota
ok so it got to the point where i couldn't keep any coolant in the motor, so i parked it last thursday. after waiting to get the truck in the garage it got warm out so i started on it yesterday. the pump was shot along with the bypass hose and lower radiator hose. so last night i went one step further and bough an electric fan lower radiator hose and a brand new water pump with lifetime warranty. this morning i got it all installed but i can't decide if i wan both fans to kick in at the same time or have one on the low side and one on the high side...
Old Dec 31, 2010 | 02:49 AM
  #26
JDakota92's Avatar
JDakota92
I would change out the thermostat as well, while you are there. I've replaced the waterpump, bypass hose, both radiator hoses, and the radiator on my '93. On these trucks, it's best to do the wp, bypass hose, and thermostat all at the same time. My experience has been that when one goes, the others will soon follow.
Old Dec 31, 2010 | 04:16 PM
  #27
mazda7475's Avatar
mazda7475
all the gen 1 daks have a " weep hole " in the bottom of the water pump if the seal goes bad antifreeze will leak out, the clockwise rotation of the fan will spray it into the alt.
Old Jan 2, 2011 | 08:19 PM
  #28
shadowthedakota
i did change the i took the thermostat out and tested it. it was still good so i threw it back in. i do get good heat...till i turn the fans on. they cool the truck down to fast...lol but for some strange reason the fan controller won't kick them on so i'm stuck turning them on manually right now. i did find the weep hole after i took the pump out.
my Grandfather says my waterpump will outlast the truck now...lol
Old Jan 5, 2011 | 01:53 AM
  #29
oxygen454's Avatar
oxygen454
One most vehicles that I know of (like the camaro I had), when the fans dont kick in, its because the coolant sensor was faulty. I did not know it was overheating.
Old Jan 5, 2011 | 08:56 AM
  #30
shadowthedakota
i picked up a cheap one yesterday from autozone and its been working ever since. so far in normal city driving its kept the temp down to below half and on the highway it doesn't even turn on(not that it needs to). i'll be keeping an eye on it though for the next week or so.
