waterpump issue?
Heads up to any one doing water pump on Dodge 98 Dodge Ram2500 V8 5.9 gas and possibly other engines . if removin water pump specifically a 7 bolt on pump ... The two lower bolt holes on the pump opposite of each other go thru into the timing chain cover and above the oil pan. ...so caution keep these plugged during any water pump work or water will enter your oil pan thru the timing chain cover .. Why this is not pointed.out any where in Chryslers shop manual i have no idea. So beware all Dodge diehards ..ive ben to auto school in the 80s and been turnin wrenches since 1980 . Dodge Die Hard till im Dead.
I would think as a rule that working on the WP ie removing its bolts, you would first drain the coolant system thus preventing that problem.
edit-Yup just checked the first step for servicing the 2.5 WP and the second step for the 3.9/5.2 WP is drain the coolant system.
i crawled under the truck this morning with a flashlight. the whole passenger side of the water pump where it meets the block is covered in coolant so i checked up by the thermostat and it was dry. looked at the left side of the water pump was dry too. sound like a bypass hose? if it is would it be best to change the water pump at all or no?
Where is the bypass hose located? I get a steady stream intermittently. Flushed system multiple times to clean. No leaks, one day later slow drips (not running) steady stream @ idle. Appears to be from pump weep hole.
The bypass hose in under the AC unit on my 94 which I think is mostly the same as your 93. Good news you can unbolt it and lay it over to the passenger side w/o having to deal with refrigerant. Bad news you may need to change the water pump. It's involved consider doing the timing chain while you are there, you will have complete access to it.
Helpful tip is to put the bolts you remove from the old pump in the new one so you know where they go(they are different lengths). If you don't have a t stat with the air bleed valve drill a small hole in the body it will save you the headache of getting the air out of the system. See post #14 here.
