True??...
Old Dec 17, 2010 | 09:21 PM
VINCE 91's Avatar
VINCE 91
Default True??...
I was told that if I remove my fan clutch set up and put an electric fan kit in my 91 / 318, there would be a pretty decent power / economy gain. Comments?
Old Dec 17, 2010 | 10:21 PM
Z Guy's Avatar
Z Guy
you should notice slightly less drag... i didn't notice a huge difference
Old Dec 17, 2010 | 10:28 PM
siggie30's Avatar
siggie30
I have seen this countless times. First off, the clutch fan has less maintenance requirement, and lower impact of said maintenance costs. Secondly, while you may get a few extra ponies, it is not all the time. When your electric fan initially kicks on, there is a draw on the battery which, in turn, puts a load on the battery that requires extra drag via the alternator. So yes, and no. For even a light build, I would recommend the clutch fan until you get serious enough to want to squeeze every ounce. Unless your really really bored and want to do something, but I am sure you have allready swapped exhaust, heads, cam, intake, gears etc. I would not recommend it on a street duty vehicle.
Old Dec 18, 2010 | 12:03 AM
VINCE 91's Avatar
VINCE 91
Well I guess I'll leave it alone then. Thank you gentlemen!
