tranny leak
it is a big chunk. the trans ran fine,just was leaking out in front of the bell housing. Wouldn't it have chomped every thing in side if it was floating around in there? Thats why i pulled it to replace the front seal
Ok tranny is in, all hooked up. Found that chunk. It was wedged in the hole. Got it out.
Now i have a question on a hose hook up.
On the 4wd there are 4 tubes running from the t-case to the front of truck. On the pass side 2 goes to the front axle. Drivers side it breaks out to two. One is capped with a breather looking valve while the other plugs into soothing. Can anyone tell me or take a pic or draw a diagram where this vac hose goes.
Thanks in advance.
Thanks in advance.
www.autozone.com has a full list of vacuum diagrams. This one should work. It doesn't list the 4wd but look for any hoses/valves not connected.
im sorry u lost me . 4 steel tubes go from the vacuum switch on the tc. to the front of truck. onn the pass side the the tubes split and go 2 tubes connect to the the vacuum solenoid on the front axle. the other 2 go towards the drivers side. 1 is capped off with vent cap. The other runs???? this is the one i need help with.
Crazy sent me a vacuum diagram and it helped with two out of place hoses,but not for the one im looking for. any help plz..
Thanks
Thanks
