Transmission issue
Old 01-13-2011 | 01:26 AM
siggie30's Avatar
siggie30
Originally Posted by daneek155
ok well i got that haynes book, it says to torque it to 72 than go 2 7/8 turns back. is that caculating that one turn is 360 degrees
There is the band bolt and there is the locking bolt. Yes, 720 degree's, then an additional 315 degrees. The pitch of the bolt threads will determine the proper gap spacing after you "go back". Then tighten the locking bolt to the specified torque.
Old 01-13-2011 | 02:45 AM
Crazy4x4RT's Avatar
Crazy4x4RT
Old 01-13-2011 | 10:51 AM
daneek155's Avatar
daneek155
thanks
Old 01-15-2011 | 03:45 PM
dalemoser's Avatar
dalemoser
Default might be a little late
if u adjuted the band,and changed the fluid,and it helped that is great.i hope all thet was for no sugnificant change.now,here is a good idea also,didnt look to see where you are from,so dont really know how cold it gets,or if u warm your truck up,rather than just jumpin in and takin off.but here is a suggestion,if you warm ur truck up,or u sit at an idle,like for instance in a parkin lot,put the transmission in neutral instead of park.in rear wheel drive mopar transmissions,the transmission pump does not pump in park,only in neutral and in gear.alot of people dont know that,and after years of being warmed up in park fluid gets schorched,parts get burnt up,basically transmission failure,just a little tip,that will help get a little more life out of your tranny.
