Gas filler tube rubber seal
Old Mar 3, 2011 | 08:19 PM
kahanabob's Avatar
kahanabob
Default Gas filler tube rubber seal
90 V6 will be removing the bed to do famous sending unit fix. the rubber seal where the filler tube goes into the tank looks a bit cracked and don't know if the filler tube will fall off when i remove the bed. afraid it might crumble and fall apart anyone know where i can get a new rubber seal?
Old Mar 4, 2011 | 02:25 AM
Crazy4x4RT's Avatar
Crazy4x4RT
Here is a similar problem. Maybe he knows more. If you haven't tried check www.autozone.com or www.napaonline.com or your local dealer.
https://dodgeforum.com/forum/1st-gen...kota-help.html
Old Mar 4, 2011 | 09:52 PM
eddys89vert's Avatar
eddys89vert
dodge sells it. same seal for most dodge products. i paid 20 bucks today.
Old Mar 5, 2011 | 06:59 PM
Dodge4lyfe's Avatar
Dodge4lyfe
mine leaks too, good to know the stealership has it...
