92 3.9 fan clutch
Old Mar 16, 2011 | 03:51 PM
spatton's Avatar
spatton
Default 92 3.9 fan clutch
I had a question on this does the fan spin either way and what i mean is from the pulley like i hold the pulley and i can move the fan blades either way is this good i have the belt off if that helps or is the nut loose?
thank you for any suggestions.
Old Mar 16, 2011 | 05:20 PM
95_318SLT's Avatar
95_318SLT
Yes. The fan blades are attached to the pulley by a temperature sensitive fluid clutch, so when it is cold, the blades should spin free.
Old Mar 16, 2011 | 05:26 PM
Crazy4x4RT's Avatar
Crazy4x4RT
The fan can spin by hand both ways, but the engine only turns it one way (Clockways from looking at the motor). In the FAQ2 there is a write up on ways to remove the nut.
