v6 to v8 torsin bar help
Old Mar 20, 2011 | 01:05 AM
walkerman2188's Avatar
walkerman2188
Default v6 to v8 torsin bar help
im sorry 4 all the questions guys but i don't have the money or the tools to do alot of stuff to lift my dakota but can any 1 tell me if changing the v6 bars to the v8 bars work and if they had to do any modifications too thanks
Old Mar 20, 2011 | 01:44 AM
Crazy4x4RT's Avatar
Crazy4x4RT
Yes the swap will work and will be a simple swap. Lift keys will give the same results.
Old Mar 20, 2011 | 02:14 AM
walkerman2188
which ones do i get the 4x4 dodge 1500 or the 2wd dodge 1500 torsion bars
Old Mar 20, 2011 | 02:17 AM
Crazy4x4RT's Avatar
Crazy4x4RT
The Rams don't have torsion bars, 4wd or 2wd. 92-96 Dakota 4wd V8 torsion bars will work (2wd doesn't have torsion bars). Try the Junkyard. www.ebay.com has good prices on lift keys. $60 or so.
Old Mar 20, 2011 | 02:30 AM
walkerman2188
how much more of a lift will i get
Old Mar 20, 2011 | 02:48 AM
Crazy4x4RT's Avatar
Crazy4x4RT
1in or so.
Old Mar 20, 2011 | 10:46 AM
walkerman2188
i would get the lift keys but i have a 89 dakota 4x4 and the lift keys i found was for 91 to 96 dakotas would they still fit
Old Mar 20, 2011 | 12:07 PM
Crazy4x4RT's Avatar
Crazy4x4RT
I believe they still work. Double check this site, he installed the full suspension kit on a 89 when it is for 91-96. Also the V8 torsion bars would be 91-96.
http://www.walt-n-ingrid.com/modific...tml#Suspension Lift
Old Mar 21, 2011 | 08:25 PM
verdesardog's Avatar
verdesardog
If you get v8 torsion bars you can get about 2" lift but it will also ride harder as the v8 torsion bars have a higher spring rate. I have heavy duty v8 torsion bars on my 94 v6 with 2" blocks in the rear and my truck sits level even with a winch on front.
Old Mar 21, 2011 | 08:28 PM
verdesardog
Attachment 12363
