Help! Bolt threads in Steering Knuckle Stripped
Old Mar 27, 2011 | 10:50 AM
JDakota92's Avatar
JDakota92
I had that happen to me the last time I did lower ball joints, ended up replacing the knuckle from a junk yard unit.
Old Mar 27, 2011 | 01:56 PM
oxygen454's Avatar
oxygen454
How much did your knuckle end up costing ya? I hear they are fairly pricey.
I was thinking of last resort, welding up the knuckle and tapping. That would be a lot of work. First the Knuckle should be removed but could be done on the truck. Then, I would have to clean and preheat the knuckle. Also making sure that I had some long cross hair lines to be able to find where the hole had to be again. Then weld and post heat, cover and slow cool. I believe the knuckle is cast steel.
Im really happy that the tapping caliper pin worked.
