Front Brake Issue
Old Mar 28, 2011 | 10:56 AM
kahanabob's Avatar
kahanabob
Default Front Brake Issue
1990 V6 LE Auto. when comming to a stop the truck will pulsate, it feels like i am slightly letting off and then pushing the break pedal, but i am not and i don't feel it in the pedal. hard to explain, is like a reverse surge when breaking and can feel it in the steering wheel, it kind of pulsates back and forth slightly. pads are good only thing i can think of is something to do with the rotors?
Old Mar 28, 2011 | 11:18 AM
festerw's Avatar
festerw
More than likely it is the rotors, either replace them or have them turned. I believe properly torquing the lug nuts can help in preventing this problem in the future.
Old Mar 28, 2011 | 09:58 PM
marcar1993's Avatar
marcar1993
Yes it is the rotors, lug nut tq has nothing to do with it though. The rotors warped from heat of use. Turn them or replace them. Also do pads though when you do it.
Old Mar 29, 2011 | 01:08 AM
festerw's Avatar
festerw
Lug torque can contribute if you've got every nut torqued to a different spec the rapid heating and cooling of the rotor will cause different stresses at each nut.
I'll say this I've torqued the lugs on every vehicle I've owned by hand even after they come back from a mechanic and in 15 years have never replaced a rotor due to warping. May be coincidence but I'll take the extra time.
Old Mar 30, 2011 | 11:31 AM
kahanabob's Avatar
kahanabob
mine is 2WD looks like if i replace it is the entire hub. do i need to press out the bearings and is this going to become a goat rope and i will have to replace all the parts that go in the hub?
Old May 21, 2013 | 02:42 AM
RyanWallace's Avatar
RyanWallace
Default 1994 dodge dakota 5.2
I have a 1994 dodge dakota with a 5.2 2wheel drive. I'm looking for the passenger wiper pivot arm
Old May 21, 2013 | 01:54 PM
inuchan187's Avatar
inuchan187
@ RyanWallace,
It is located between the engine compartment and the windshield.
Old May 22, 2013 | 10:15 AM
RyanWallace
Yes its the part the wiper arm goes on.
