Wiper linkage problem
Old Mar 28, 2011 | 12:06 PM
Soundguy's Avatar
Soundguy
Default Wiper linkage problem
Part of the linkage jumped off when I turned them on high causing both wipers to quit. It looks like some kind of plastic nut I need, but can't find the part yet.
Any suggestions?
Old Mar 28, 2011 | 12:17 PM
festerw's Avatar
festerw
I'm guessing the wiper bushings are what you need, never had to do them myself but they should be available at any parts store or dealer.
http://www.napaonline.com/Search/Det...+50022+2022006
Old Mar 29, 2011 | 11:50 AM
Soundguy's Avatar
Soundguy
Thanks! I got an asst. pack of Dorman bushings at the zone, but found out I need more than what's in the package so, I'll be going to Napa to get those.
Old Mar 29, 2011 | 12:43 PM
kahanabob's Avatar
kahanabob
when you install be careful not to get the linkage arms mixed up. take note of upside vs down side they need to go back exactly the same. can easily mix up, i would use some kind of marking system. also when you install new ones they need to pop into the holes on the linkage. I used a vise.........again, take on old one out and install the new one don't pop out all the old ones you will forget which way they go...lastly, change all of them not just the broken one or you will be in there doing it again in no time.....been there done that to my 90.......
Old Mar 30, 2011 | 05:06 PM
Soundguy's Avatar
Soundguy
I changed them all and lithium greased 'em too. I had to go to the dealership for one of the bushings....the one with the hole in it. $12.00 for that one.
Oh well, works like new now and hope I don't get stranded on the interstate in a t-storm for awhile.
This link helped some too....
http://hubpages.com/hub/How-to-Repla...Wiper-Bushings
