Temperature "sensor" wiring
Old Apr 24, 2011 | 10:22 AM
siggie30's Avatar
siggie30
Default Temperature "sensor" wiring
New thread to simplify searching:
I am wanting to wire a electric fan (non-stock) to turn on from the stock "sensor". I noted in the FSM that one point grounds and the other point goes to the computer, but it does not say (or rather I cannot decipher) if it is a resistance type sensor or not. I assume that I can wire the sensor to the relay, and chassis ground the opposing wire. Is this correct?
Old Apr 26, 2011 | 06:50 PM
Crazy4x4RT's Avatar
Crazy4x4RT
You can buy a sensor relay kit to make them turn on and off. Some are adjustable. Autozone has them also www.summitracing.com
