help me!!!
Old May 26, 2011 | 09:57 PM
redneckdakota32131's Avatar
redneckdakota32131
Default help me!!!
Ok I recently installed a new trany in my 94 318 dakota I broke the crank senor in the process I repaced it and the rod it's throwin an 11 and 22 how do I fix this?
Old May 26, 2011 | 10:04 PM
redneckdakota32131
Tps not rod
Old May 27, 2011 | 01:57 AM
Crazy4x4RT's Avatar
Crazy4x4RT
So your getting code 11 and 22 is that what your saying?
Did you reset the computer after?
https://dodgeforum.com/forum/1st-gen...-96-codes.html
11** Timing belt skipped 1 tooth or more from initial learned value, Intermittent loss of either camshaft or crankshaft position sensor, No crank reference signal detected during engine cranking
22** Engine coolant temp sensor signal outside the acceptable range
Old Jun 4, 2011 | 02:29 PM
DRUSS25's Avatar
DRUSS25
I just changed my trans too...thinking I may have the same problem...rolls over and tries to fire but just won't go...just kind of shakes and burps around...I sprayed starting fluid right down in the throttle body and still no go...pulled cap n rotor, cleaned up the contacts..still no go...
How do you change the CPS? I looked up a new one and it has a bracket on it...does the trans have to be pulled away from the engine to change it?
Old Jun 4, 2011 | 02:43 PM
Crazy4x4RT's Avatar
Crazy4x4RT
No just unbolt the 2 bolts and pull out.
Old Jun 4, 2011 | 02:48 PM
DRUSS25's Avatar
DRUSS25
Is that the sensor thats between the engine and trans on the passenger side, towards the top? Has the little notch for it?
Old Jun 4, 2011 | 02:56 PM
Crazy4x4RT's Avatar
Crazy4x4RT
Yes it is.
Old Jun 4, 2011 | 05:05 PM
DRUSS25's Avatar
DRUSS25
Well...that wasn't it...had it tested at autozone and it checked out good...
