LA 360 swap help
Old Jun 19, 2011 | 12:09 PM
siggie30's Avatar
siggie30
Originally Posted by bill55az
Mine will be a very basic "town" truck, no power steering, no AC, just a balanced 330HP LA360 with Magnum heads and 92-93 exhaust manifolds, 3" single exhaust, 727 with floor mounted cable shifter and cable kickdown , 3.55 suregrip.....and a 125mph speedometer....
The dirty engine shown in the chassis now is a Magnum engine, using it for the mockup to make sure everything fits.
If I use the Magnum exhaust manifolds, it is a tight fit from Y pipe to passenger side frame, so I have moved the engine towards the drivers side about a half inch or so....
But I am thinking about headers....and dual exhausts. That means a new gas tank where the spare tire goes....
That's the plan....
You "can" crossover your driver side exhaust between the oil pan and the transmission and run double exhaust rearward to accomodate fitment above the trans bracket. This would negate changing other systems.
Old Jun 19, 2011 | 12:19 PM
bill55az's Avatar
bill55az
2 smaller pipes parallel would certainly go over the tranny Xmember easier than the 3" pipe I have now....
Then come back together in a dual inlet cat, with a big outlet to a big muffler, or go true duals all the way back on the passenger side. there....
I already have the dual inlet cat and a fat muffler....
