Normal or bad oil pressure sending unit?
I made a video:
http://www.youtube.com/watch?v=wC3ZS4njqL0
Watch 1:05 to end, or the whole thing.
Is this normal? On my Ranger the oil pressure is always in the middle.
95 Dodge Dakota 3.9L V6
Looks normal. The needle may move, but should peak at 2,000 rpm. Your pressure shows a little low initially. I am confident that your oil fluid is full. Not knowing your engines history, I would suspect pump failure or rather a worn out pump if it idles with low pressure. Most replace the sensor as they are known to be faulty after a gagillion miles (actually, I believe it is normal for the sensor swap, but most think their parts should last for the lifetime of the chassis and typical maintenance does not apply to them).
