94 Dakota EGR system help
Old Jul 16, 2011 | 05:19 PM
jimr312's Avatar
jimr312
Default 94 Dakota EGR system help
I have a 94 Dakota 3.9L. I recently got a check engine light with a code 32 (EGR system). I installed a new EGR valve but still get the code 32.
The check engine light is not always on. It is usually out when I first start the truck and then comes in a few miles down the road. Sometimes it doesn't come in unless I accelerate fairly hard.
I have checked for loose/broken/ cracked vacuum lines and haven't found any. Any suggestions?
Old Jul 17, 2011 | 02:07 AM
Crazy4x4RT's Avatar
Crazy4x4RT
Since you tried replacing the EGR valve and checking vacuum lines, next would be bad wiring or a clogged lines.
Old Jul 17, 2011 | 03:35 AM
jimr312's Avatar
jimr312
I did that alredy, was the first thing I did.
Old Jul 17, 2011 | 07:36 PM
jimr312's Avatar
jimr312
Clogged lines I can check for. How would I go about checking the wiring? Just basic voltage/resistance checks at the connector is what i would assume, but what numbers would I be looking for?
