master cylinder lines to proportioning valve
Old Aug 20, 2011 | 09:31 PM
hogback's Avatar
hogback
Default master cylinder lines to proportioning valve
ok just need quick help can somebody see on their Dakota if the line that is closest to the front on the master cylinder goes to the place closest to the front on top of the proportioning valve thanks and where can i get a new T fitting for the front where it comes from the prop valve and then splits to the 2 front wheels
Old Aug 21, 2011 | 07:13 PM
Crazy4x4RT's Avatar
Crazy4x4RT
I hope this pic helps from the service manual which you can download from the FAQ in this section if you need more help or diagrams. As for the T fitting try your local Dodge Dealer parts department or Napa or your local junkyards.
Old Dec 7, 2013 | 10:27 AM
ldaniels12467's Avatar
ldaniels12467
dodge brake proportioning valve diagram for 1993 ram 350 5.9L or chassis wiring diagram
