Truck tries to die while driving
Old Sep 2, 2011 | 10:11 PM
iluvtolaff's Avatar
iluvtolaff
Default Truck tries to die while driving
This is for a friend...
He has a '92 Dodge Dakota truck and it keeps trying to stall while driving.
3.9 liter v6 and standard tranny
generally stalls when acceleration but sometimes in motion
Check engine light on? No
Does it restart after it stalls? doesn’t die completely, just chokes down and acts like it wants to die
What repair work has been done to it recently? new plugs, wires, fuel filter and checked distributor cap and rotor
Any help is appreciated.
Old Sep 3, 2011 | 02:02 AM
Crazy4x4RT's Avatar
Crazy4x4RT
Sounds like it doesn't want to idle. First guess is the IAC Idle Air Control valve, they are notoriously bad even lots of new ones are bad.
Old Sep 3, 2011 | 11:01 AM
iluvtolaff's Avatar
iluvtolaff
The IAC-- would it need to be cleaned or replaced?
Old Sep 5, 2011 | 11:41 AM
RockGuardedDak's Avatar
RockGuardedDak
try cleaning it with intake cleaner first, and if that doesnt work, get a new one. just outta curiosity, what kinda of plugs did he put in? These motors don't seem to like platinum plugs...
Old Sep 5, 2011 | 12:34 PM
iluvtolaff's Avatar
iluvtolaff
I'll ask him this evening. I think he was going to clean it first. I'll get back to you. Thank you!
Old Sep 5, 2011 | 03:57 PM
kahanabob's Avatar
kahanabob
not sure if the 92 has a in-line fuel filter along the frame rail if so might change.
Old Sep 5, 2011 | 06:32 PM
iluvtolaff's Avatar
iluvtolaff
He finally got someone to look at it. They think it was the EGR valve. I'll find out later if that was it. Thank you!
Old Sep 6, 2011 | 01:39 AM
JDakota92's Avatar
JDakota92
'92 does have an inline filter. Check fuel pressure as well. Possible failing pump.
Old Sep 6, 2011 | 12:48 PM
iluvtolaff's Avatar
iluvtolaff
Thank you. I'll tell him.
Old Sep 7, 2011 | 03:06 PM
iluvtolaff's Avatar
iluvtolaff
He still doesn't know if it was the EGR valve or not. He said he needs to run a vacuum test first to see if the valve is bad or just the mounting gasket is leaking.
