Best head lite lens restore kit?
Old Sep 23, 2011 | 11:06 AM
qlty94's Avatar
qlty94
Default Best head lite lens restore kit?
Which brand is the best.My 94 dak's head lites are really bad (hazed over) to the point driving at night is NG.can i just use rubbing compound followed with a polish? or?
Old Sep 23, 2011 | 11:11 AM
Rabid21's Avatar
Rabid21
The kit 3M makes is decent enough if you follow the steps properely.
I used it a few times when I was working at a shop detailing Harley's along with on my own truck.
Most part stores should have access to it I think
Old Sep 23, 2011 | 12:49 PM
marcar1993's Avatar
marcar1993
Honestly, don't waste the money on a kit. Get some really fine grit sandpaper 1500-2000-2500 and wet sand the lenses. Then get some rubbing compound and polish them out. Always worked for me.
Old Sep 23, 2011 | 10:29 PM
Shelbyfan's Avatar
Shelbyfan
I found a perfect set of TYC aftermarket at a local used parts shop for $50. It was easy enough to swap it over and took less time than when I polished one out. Just make sure you get the lock ring for the headlight, they are NOT all the same. It is also a good idea to spray the bolts with wd40 before you take them out, mine were rusted in.
A long phillips screwdriver and a 10mm socket was all it took. Rockauto.com has them for $66. More expensive but a longer and better fix.
Old Sep 24, 2011 | 12:12 AM
g. man's Avatar
g. man
I bought RainX brand I think, and it worked pretty well. There were a lot of steps involved. Came with three different sanding pads, and a few different bottles of cleaners, and such. It was around 15 bucks or less. I think next time I would get the one with the attachment for your drill.
Old Sep 25, 2011 | 01:38 AM
Rabid21's Avatar
Rabid21
Thats what is nice about the 3M one I think
Comes with the Drill attachment and all the sandpapers are cut to size so they fix on it along with the foam pad.
Old Sep 25, 2011 | 12:54 PM
qlty94's Avatar
qlty94
I bought the store brand (same as the 3M) at "Harbor Freight" yesterday for $10.00 after reading good reviews and they cleaned them up fairly good,I plan to try polishing them up some more for better results but can see a big difference already.Thanks all for the reply's.
