speedo/tranny issue?
Old Sep 23, 2011 | 04:38 PM
Buellstunter's Avatar
Buellstunter
Default speedo/tranny issue?
Ok, I have a 1995 dodge dakota ext. cab. 2wd 3.9l v6 automatic. Recently I noticed the torque converter hasnt been locking up at 40mph as it used to. Was gonna change out the solenoid but havent had the time. Today driving home from work the speedo started fluttering and then dropped to 0. at the same time the tranny dropped out of overdrive. Shortly after it quit the check engine light came on. (havent checked code yet. dont have my scanner right now) the rest of the way home it would not shift into overdrive. when the speedo started working again it would shift. So that said i have to assume that my speed sensor is going bad. Is the speed sensor on the rear axle housing top front center or on the tailshaft of the tranny? Any help is appriciated
Old Sep 23, 2011 | 05:17 PM
RockGuardedDak's Avatar
RockGuardedDak
I'm not sure about the 95, but on my 93, it's on the tailshaft of the tranny. Very easy to change! Just kind of an expensive sensor
Old Sep 23, 2011 | 08:30 PM
dodgerules86's Avatar
dodgerules86
Speed sensor is indeed in the tailshaft the transmission on 2WD, on the output shaft of the transfer case on 4WD.
Old Oct 25, 2011 | 03:55 PM
lakota74's Avatar
lakota74
wheres it located on the 46 re tannys? 98 dakota 318 4x4... no speed on the dash.. ??
Old Oct 25, 2011 | 05:52 PM
g. man's Avatar
g. man
Your also in the wrong forum. Try the 2nd gen dakota forum, and search or post a new thread. :ic on_verzsilly:
Old Oct 26, 2011 | 02:02 AM
Crazy4x4RT's Avatar
Crazy4x4RT
The post above yours already answered it.
Old Oct 26, 2011 | 03:57 PM
Buellstunter
My speedo issue turned out to be the sensor on the top of the rearend.
