Anti-lock Break light
Old Sep 25, 2011 | 01:35 PM
silver92's Avatar
silver92
Default Anti-lock Break light
I Have a 92 Dodge Dakota Pickup and i just had to replace the ignition coil and now after leting the truck run for about a 45 seconds the Anti-lock break light comes on along with the Parking Break light and so naturaly i pull the break latch and i realize that i hardly set the parking break and i dont know why the 2 lights are coming on along with the fact that i dont have ABS on my Dakota
any help would be apreaceated
Old Sep 25, 2011 | 03:13 PM
Crazy4x4RT's Avatar
Crazy4x4RT
Yes you do have ABS Rear Wheel ABS RWABS. It came factory on all 92? and up.
Check fuses. The FAQ has a write up on how to check the codes to see what it could be. It is a few posts above this one.
Old Sep 26, 2011 | 06:14 AM
dodgerules86's Avatar
dodgerules86
Like Crazy said, view https://dodgeforum.com/forum/1st-gen...ake-light.html this thread for more information (I haven't read it all).
In the past, a common reason for both of those lights going on (yes, BOTH at the same time) is a problem with the rear wheel ABS speed sensor. This part is located in the top of the rear axle housing (pumpkin).
But, there are other reasons the light can come on. See link.
Old Nov 15, 2011 | 01:41 PM
1stgen318ci93's Avatar
1stgen318ci93
if your tail lights are going out you should check your tail light bulbs. sounds dumb but after checking everything that could be causing a short circuit on my truck i found that it was being cause by a faulty light bulb. Every time i would press the brake pedal the fuse would blow causing the brake and abs lights to come on(dashboard) and the tail lights to shut off. i hope that helps you out.
