92 computer bad?? anyway to test??
Old Sep 29, 2011 | 10:29 PM
g. man's Avatar
g. man
Originally Posted by dodgetruck2
My 92 has no spark, and we cannot can any sort of signal or anything out of the wire that comes from the computer and plugs into the coil. We have tested continuity and the wire is good so it must be the computer not sending a signal. I was wondering if I could swap in a new computer that is know good and see if that fixes the issue. Then maybe I could have the compter repair or something, probably replace it.
The shipping costs for one. And if you read his post, he doesn't need a new engine. He isn't getting spark. No one would replace a whole engine because of this.
Old Sep 29, 2011 | 11:46 PM
dodgerules86's Avatar
dodgerules86
... I think logancounterman means mailing the engine computer. (Thus the thread title)
Old Sep 30, 2011 | 08:40 AM
logancounterman's Avatar
logancounterman
yea the computer..... lol i do have a whole motor too. but i mean the computer.
Old Sep 30, 2011 | 10:27 AM
g. man's Avatar
g. man
Sorry
Old Sep 30, 2011 | 06:05 PM
dodgetruck2's Avatar
dodgetruck2
Well I have been told cam/crank sensor before so I want to rule them out first. How do I test them to make sure everything is getting/giving signal?
Old Sep 30, 2011 | 07:08 PM
Hahns5.2's Avatar
Hahns5.2
First you need to verify the ASD relay is energizing, if the relay isn't bad itself, then it's likely the cam sensor or bad wiring.
If the coil isn't getting it's signal to fire it could very well be the crank sensor.
Old Sep 30, 2011 | 11:09 PM
dodgetruck2
I have no doubt in bad wiring, the relay is good we did a test on it outside the vehicle. This truck sat a year or two and I have seen a couple bad wires. Is there a way to test it without visually inspecting every inch of the wire?
Old Oct 3, 2011 | 06:04 PM
dodgetruck2
What would you be looking to get for the computer? I have no signal coming into the asd relay, however, two pins have constant power. I am assuminmg one is the power to energize the relay, and the other is the power that is being switched by the relay.
Aslo got a couple pluggins that have no home.
Bottom one is 3 prong and top one is 6 slotted with only 4 usable prongs
Old Oct 3, 2011 | 08:18 PM
Hahns5.2's Avatar
Hahns5.2
Does the ASD relay energize for a couple seconds when the key is first turned on? Did you check while cranking?
Old Oct 4, 2011 | 04:12 PM
dodgetruck2
I checked while someone turned the key and then cranked it and only have power at the two prongs with constant power
