fuel gauge issue
Old Oct 15, 2011 | 12:05 PM
druski's Avatar
druski
Default fuel gauge issue
Hi guys got a 93 5.2 dakota and noticed the other day my gas gauge started bouncing around when i was stopped at a light. Now its doing it more often, so my ? is do i have a bad float or is it an electrical issue? If its a float issue can i replace just the float or do i have to replace the whole unit?
Old Oct 16, 2011 | 08:18 PM
LittleBlue84's Avatar
LittleBlue84
I had that problem in my '93 and it turned out to be the fuel sender unit.
Old Oct 16, 2011 | 09:34 PM
druski's Avatar
druski
Ok thanks so I have to take the bed off or drop the tank to get to it?
Old Oct 16, 2011 | 11:13 PM
Crazy4x4RT's Avatar
Crazy4x4RT
Yes correct.
Old Oct 17, 2011 | 05:09 AM
dodgerules86's Avatar
dodgerules86
You can do either.
If the tank is full of fuel, you're best bet it removing the bed.
If the tank is empty, well, I'd still remove the bed, but some people claim it's not bad dropping the tank.
I removed the bed when I had to do some work. It was easy. Just don't forget to disconnect and than reconnect the electrical harnesses.
Old Oct 17, 2011 | 09:30 AM
qlty94's Avatar
qlty94
Here is what I did on my 94 Dakota club cab.remove 4 screws on fill hose shroud,remove 4 bed bolts on drivers side ,loosen but leave in 4 bed bolts on passenger side,make sure tail lite wiring has enough slack or take connecting plugs apart.Bed is light enough so one person can lift while other (wife) puts timbers between frame and bed.An old bumper jack came in handy.
Old Oct 18, 2011 | 12:44 AM
DarkKnite2009's Avatar
DarkKnite2009
if your going to check out the float in the tank you my want to check out the connections for the float you might get away with not spending anymoney
Old Oct 18, 2011 | 10:43 PM
druski's Avatar
druski
Thanks I will try and work on it this week end just filled the tank so the bed is a good plan
Old Oct 18, 2011 | 11:05 PM
shadowthedakota's Avatar
shadowthedakota
its probably the float breaking contact with the sending unit...i had that problem with mine where the float was worn on the post it pivots on and the little tabs kept breaking contact. bending the tabs outward more will fix the problem if that is the problem...
Old Oct 19, 2011 | 10:28 AM
qlty94's Avatar
qlty94
if it was me and it was not simply the connections rather than pull the pump I would just use the trip odometer and figure on a 12 mph average consumption on the 22 gallon tank.
