No change in shaking
Old Oct 22, 2011 | 09:54 AM
1stG92's Avatar
1stG92
Default No change in shaking
92 3.9 2wd LE
What I thought was the rear end going turns into being false.Good news but,violent shake still present.This is costing me more time than money but TOO MUCH time.I just have no idea where to look next.I guess my question would be now,Would a bad transmission make my truck shake like it is?I cant even get a block away before it starts in.Yesterday after checking rear end I took it for a short drive and felt the shake start almost immediately as I took off and got worse as I kept going.I'm wondering if anyone else has come across this issue with their Dakota?Here is a list of things I've looked at..Suspension,ball joints,u-joints,tires,rear end.Having the drive shaft and transmission checked today.I have never had a transmission make a vehicle act like this before but Im no transmission guy so..... Although I have changed both u-joints and drive shaft seemed fine.This truck is in too nice a shape to give up on but if I don't find the issue soon I'll be forced to sell it for parts...ANY information you guys have to help save this little beast is greatly appreciated.
Old Oct 22, 2011 | 10:46 AM
Spire's Avatar
Spire
Does the shake start at a certain speed and if so what speed? Are there any noises that are associated with the shaking? Does the shaking seem to come from a certain part of the truck?
Old Oct 22, 2011 | 02:52 PM
RockGuardedDak's Avatar
RockGuardedDak
have you hit any curbs lately? a bulged tire can shake the truck pretty bad depending on the bulge. another thing to check would be wheel bearrings in the front. like Spire asked, is it speed related? does the temperature outside make a difference?
Old Oct 22, 2011 | 03:13 PM
dobaroy's Avatar
dobaroy
Start the truck up, put the gear shift in neutral. Then rev the motor and see if the vibration is there or not. Put your hand on the steering wheel and see if you feel the vibration.
Old Oct 22, 2011 | 09:34 PM
1stG92's Avatar
1stG92
Thanks for the fast response guys.first I did check all the bearings and they are fine and tires look good also.I dont hear any noises and vibration is from any speed,gets worse the faster you go.Seems to get the worse soon as it shifts into second gear.This is why I asked if it could be tranny related..Soon as it shifts into second THATS when ya cant even drive anymore.Truck violently ans I do mean VIOLENTLY shakes.Theres nothing sitting in neutral.
Old Oct 22, 2011 | 09:35 PM
1stG92's Avatar
1stG92
Temp doesnt make a difference..
Old Oct 22, 2011 | 10:29 PM
RockGuardedDak
have you checked the transmission mount. its another possibility i suppose, short of that, I'm stumped o.O
Old Oct 22, 2011 | 10:33 PM
Xxaler's Avatar
Xxaler
Put the rear end up on blocks, get a buddy to accelerate until it hits second and watch underneath. Sounds like a bent drive shaft. If it's bent, you'll see it when its on blocks.
If it was internal to the transmission, the way you're describing it, you would be short a few litres of tranny fluid and a good chunk of cast iron if you drove it.
Old Oct 23, 2011 | 06:18 AM
1stG92's Avatar
1stG92
Yes,checked both tranny and motor mounts.
Old Oct 23, 2011 | 06:28 AM
1stG92's Avatar
1stG92
I have had it on blocks and a question I had asked myself was should I be able to spin the tires with the tranny in PARK? I know other vehicles I've had and worked on I couldn't.Had my dad start and put in gear and he did rev a little was fine for a few seconds then started "shuttering" a little while just in idle with the tires spinning.The tires slowed right down and seemed to be "Jammed".Trying to give words to best describe it.Almost seemed as if it were catching or something on the teeth in the rear end.But looked fine.Then again,not sure what I'm looking for lol.I'll try blocking again as you said and have him accelerate into second....TY
