Need help with my 93 dakota 4x4
Old Nov 2, 2011 | 12:59 PM
darin89's Avatar
darin89
You may need to change yokes on the differentials if u joints are smaller or bigger. I encountered this last night
Old Nov 4, 2011 | 03:42 AM
mikeonetray13's Avatar
mikeonetray13
Alright.i.thought the out put shaft was a different size
Old Nov 4, 2011 | 09:24 AM
dobaroy's Avatar
dobaroy
Mike, not too sure about the '93 being one of a kind? If you find one, just match it up to your old one as close as you can.
Old Nov 10, 2011 | 01:08 PM
darin89's Avatar
darin89
i have just finaaly got mine totally running and only thing left for me is to get electric speed sensor as the 90 was still cable driven otherwise it run fine. so you should be good to go with any NP231D transfer case out of another dakota
Old Nov 11, 2011 | 12:55 PM
mikeonetray13
A guy kocally said he will sekl me a 94 case I forgot if that work but im thinking if I just buy.the.drive shaft from him I dont.need to change anything. Im pulling the case today. It is not snowing woot woot
Old Nov 12, 2011 | 04:50 PM
mikeonetray13
Default problem solving?
So, before i pull the case off, i got it started yesterday. It will not drive in gear like D or R but once it is in 4wd it will drive. It will also not go back into park once the engine is running. i can not tell if the front is working but i know the back is driving. Also smoke starts to come by the transmission if it is ran for a bit. Obviously this is not good so i have not tired again.
Is the transmission bad also, how will i be able to tell?
Will there be pieces of things in the trans oil?
Old Nov 15, 2011 | 10:18 PM
darin89's Avatar
darin89
Crawl under near front of transmission pan and look at bell housing and dipstick area the input seal might be leaking or cooler line
Old Jan 24, 2012 | 11:21 AM
mikeonetray13
alright so i have it off but i cant find any at junk yard, if i pull one off a jeep or chevy and switch parts would that work? has anyone ever did that
Old Jan 24, 2012 | 12:31 PM
Crazy4x4RT's Avatar
Crazy4x4RT
No other manufactures parts wont work. If you want to rebuild it Napa sells the Rebuild kits for $200, less then a used transmission. The service manual in the FAQ shows how to rebuild it.
Old Jan 25, 2012 | 12:33 PM
mikeonetray13
I mean the transfer case not the trans can it still not work
