radiator replacement
Old 10-30-2011 | 08:54 PM
d5park's Avatar
d5park
Default radiator replacement
I am in the middle of replacing the radiator everything has been by the book up to what about the A/C condensor? this unit is mounted to the radiator and you can't move the radiator enough to remove the mounting screws located at the bottom. It looks like I must open the A/C system and then remove the condensor with the radiator is this correct or am I missing something?
Old 10-30-2011 | 09:35 PM
Crazy4x4RT's Avatar
Crazy4x4RT
No they are not connected together. Where do you think they are connected together? To remove the radiator, unbolt the 2 screws on the sides of the radiator and lift it up. I'm not sure what you do on the shroud but remove that and the mechanical fan first.
Old 10-30-2011 | 11:53 PM
d5park's Avatar
d5park
I agree with you and so do all the books. however the fround of the radiator has a bracket at the top of it. where the condensor has a arm that slides in then at the bottom there again is a bracket this time with a bolt that is almost impossabile to get to.
Old 10-30-2011 | 11:59 PM
Crazy4x4RT's Avatar
Crazy4x4RT
Post up a pic.
Old 10-31-2011 | 08:12 PM
d5park's Avatar
d5park
I have sent a photo showing how the condensor is connected at the top and bottom. I finally gave in and disconnected the condensor and every thing went wery smoth.
Attached Thumbnails radiator replacement-img071.jpg   radiator replacement-img072.jpg
Old 10-31-2011 | 09:08 PM
Hahns5.2's Avatar
Hahns5.2
WTF do you have the grille off? The radiator is held in by two bolts and isn't connected to the condenser, at least in 91(or 92)+ trucks.
Old 10-31-2011 | 09:19 PM
Rabid21's Avatar
Rabid21
Thats crazy...
What year and engine do you have?
I did a Rad swap on my 93 318 awhile ago and all I had to do was remove the shroud and it slid right out.
Old 11-04-2011 | 10:22 AM
bill55az's Avatar
bill55az
same here, altho I can add to this a bit....the 95 service manual tells me to remove the condensor to get at the tranny cooler. LIKE HELL I WILL !!!!
remove the shroud screws, push it over the fan blade, then remove the radiator, and the trans cooler is completely accessible...
Old 11-07-2011 | 05:54 PM
VeryOldMerc's Avatar
VeryOldMerc
I just did the radiator on a '96 3.9 auto/air. I didn't need to touch the a/c condenser. But pulling the 'quick connect' trans cooler lines off the bottom of the radiator was a PITA. Pull the coolant bottle, disconnect the upper/lower hose, unclip the top, unbolt the 2 bolts on the shroud and wiggle it off. 30 minutes +/- to remove.
Quick Reply: radiator replacement
