following the codes
Old Nov 23, 2011 | 03:46 PM
DirtMcGurt88's Avatar
DirtMcGurt88
Default following the codes
hey guys happy thanksgiving first off. well ive been trying to figure out what is causng my 95 dakota 3.9 2wd to miss for a while now. so i decided to start seeing what the codes say. the check engine does come on every so often but when you shut it off it stays off. so i just did the turn key 3X's and counted the flashes. got a 27-injector control circuit failure and a 32-egr solenoid circuit short or open circuit detected. now i did take off the egr valve and clean it and put it back on with a new gasket. still coming up although does seem to run a little better. should i replace the egr valve and the solenoid? and what is the injector control circuit? thanks for all the help so far.
Old Nov 23, 2011 | 04:45 PM
Crazy4x4RT's Avatar
Crazy4x4RT
The 27 can be anything, the injector the wires the PCM. Most likely it is a bad splice or the injector. Try to isolate which injector it is, if you get the codes read by a code reader it should show which injector it is. Or unplug one injector at a time to see which one doesn't change the way the engine runs when it is missing up.
Yes try replacing the EGR valve. Check the wiring first.
