help!!!! nv3500 swap
Old Nov 27, 2011 | 10:26 PM
92dakota4x4's Avatar
92dakota4x4
Default help!!!! nv3500 swap
I'm doing the nv3500 trans swap on my 92 Dakota 5.2. Ive read 95 318SLT's thread on how to do the swap but what I need to know is can I use my factory flywheel with the nv3500?
By the way, the nv3500 came out of a 93 Dakota 3.9 with 77k
Old Nov 27, 2011 | 10:58 PM
Hahns5.2's Avatar
Hahns5.2
No, flywheels and flexplates are completely different.
And 3.9s did not come with NV3500s until 2000, you likely have an AX-15.
Old Nov 29, 2011 | 12:35 AM
92dakota4x4
Well if that is the case, will the ax15 fit on my 5.2?
Old Nov 29, 2011 | 01:52 PM
Crazy4x4RT's Avatar
Crazy4x4RT
Yes it will but Dodge didn't put it behind the V8 for a reason. That reason is it will not last long.
Old Nov 29, 2011 | 02:19 PM
92dakota4x4
Well I'm not going to be doing any serious off roading, just commuting back and forth to work
Old Nov 29, 2011 | 02:20 PM
92dakota4x4
And I still Need to figure out if I can use my flywheel with the ax 15.
Old Nov 29, 2011 | 07:05 PM
shadowthedakota's Avatar
shadowthedakota
you have to get a v8 flywheel and the nv3500's also came behind the the ram v6's starting around '96(mine came out of a 96' ram with 125k on the clock)
Old Nov 29, 2011 | 10:35 PM
Hahns5.2's Avatar
Hahns5.2
Again, autos use flexplates, manuals use flywheels, they're completely different.
