Ignition coil
Old Dec 8, 2011 | 10:56 AM
InnerCityHillBilly's Avatar
InnerCityHillBilly
Default Ignition coil
how do you replace the ignition coil on a 1993 5.2? looks to be simple but i want to make sure what to expect
Old Dec 8, 2011 | 05:29 PM
Crazy4x4RT's Avatar
Crazy4x4RT
Unplug the wires and remove the 2 bolts that hold it down. 5mins.
Old Dec 8, 2011 | 06:08 PM
InnerCityHillBilly
i looked at some videos on youtube its a lot easier then i had thought, i dont want to put a OEM one on, what brand would you suggest? i was thinkin about an MSD coil which i can get for 49.99 at oriellys
Old Dec 8, 2011 | 06:28 PM
Crazy4x4RT's Avatar
Crazy4x4RT
MSD is usually a trusted brand, but for some reason MSD coils for the Magnum engines are junk.
My MSD coil only lasted a month tops before it left me stranded somewhere. Tons of others have the same problem with them.
I got Accel high output coil it has lasted 8-9 years.
If you got the money upgrade the cap and rotor and wires and plugs use all performance parts. If you use stock style replacements your not getting the High output/performance out of the coil.
Old Dec 8, 2011 | 08:14 PM
Hahns5.2's Avatar
Hahns5.2
Accels typically don't last either, yours sounds like the exception to the rule.
When it comes to the coil, OEM is fine.
Old Dec 10, 2011 | 12:35 AM
InnerCityHillBilly
what do you guys think of Duralast products, i have had good experience with their products and it is cheaper then MSD and ACCEL
