2wd to 4wd hanger swap
Old Dec 25, 2011 | 09:30 PM
hogback's Avatar
hogback
Default 2wd to 4wd hanger swap
i read the article about swaping a 4wd hanger into a 2wd and it will lower it. I want to do this but i want to know what i requires and does anyone have before and after pics of this my truck is a 1989 2wd 3.9l auto
Old Dec 25, 2011 | 10:01 PM
Crazy4x4RT's Avatar
Crazy4x4RT
This post will help. http://www.dodge talk.com/forums/showthread.php?t=347698
Delete the space in between the dodge and talk.
Old Dec 26, 2011 | 07:32 AM
hogback's Avatar
hogback
thanks for the article but i dont want to flip it i want to take 4wd hangers and put them on my 2wd so that it lowers it and i wanted to know if it effects anything major on the truck and what it will look like
Old Dec 26, 2011 | 08:00 AM
Crazy4x4RT's Avatar
Crazy4x4RT
It is the same exact thing.
Old Dec 26, 2011 | 09:40 AM
hogback's Avatar
hogback
yeah but you dont have to drill in to the frame and do you need to shorten the drive shaft or any thing like that
Old Dec 26, 2011 | 05:14 PM
Crazy4x4RT's Avatar
Crazy4x4RT
Yes you do have to cut the rivets out and drill out the frame.
I think your thinking of the shackle not the hanger. And the 2wd and 4wd leaf spring shackles are the same size so there is no difference in swapping them. I think you miss-read/understood what you read.
I'm assuming this is the thread you read in the beginning that you are referring to.
https://dodgeforum.com/forum/1st-gen...ut-blocks.html
In this swap you swap the hanger brackets, not the shackles. The simplest version is just to remove your stock hanger brackets and flip them.
Old Dec 26, 2011 | 06:28 PM
hogback's Avatar
hogback
yeah thats the article i read i think i will end up just flipping them. do you know how much drop i will end up with.
Old Dec 26, 2011 | 11:13 PM
Crazy4x4RT's Avatar
Crazy4x4RT
I believe 2in. https://dodgeforum.com/forum/1st-gen...le-hanger.html
Old Dec 27, 2011 | 07:45 AM
hogback's Avatar
hogback
do you know of any one who has a pic of just that done to their Dakota
Old Dec 27, 2011 | 11:29 AM
Crazy4x4RT's Avatar
Crazy4x4RT
Check my first post!!!
