How to keep overdrive on
Old Jan 3, 2012 | 10:33 AM
hogback's Avatar
hogback
Default How to keep overdrive on
my overdrive turns off every time i turn the car off i have to press it every time i start it
Old Jan 3, 2012 | 11:01 AM
Crazy4x4RT's Avatar
Crazy4x4RT
The Overdrive is always in ON mode, the switch turns the OD off. So by pressing the switch you are turning OFF the OD. Don't press the switch it is there if your towing heavy loads which you would not want OD engaged.
Old Jan 3, 2012 | 11:04 AM
hogback's Avatar
hogback
so when the OD light is on by the switch its actually off
Old Jan 3, 2012 | 11:10 AM
Crazy4x4RT's Avatar
Crazy4x4RT
Yes sir!
Old Jan 3, 2012 | 11:30 AM
hogback's Avatar
hogback
thank you i thought it was kinda weird
Old Jan 3, 2012 | 02:05 PM
DirtyHarry83's Avatar
DirtyHarry83
Sorry to side track.
I know this is a random question but I've been searching to find out what the bulb is in the OD switch. I know my switch works, but the bulb died. I figured I'd ask first before I pull the dash cover, find out the part, put it back together and go get the part, rinse repeat.
If it's unknown I'll just pull and look, and I'll be sure to note the part for anyone else on here...
Thank you
